Rubber Fuel Lines: Diameter & Length
Hi Folks,
I will be replacing my rubber fuel lines. Can anyone recommend diameter and length? I figured I'd pick up some fabric braided German rubber on eBay. You can buy it by the foot. This is for a '71 2800 CS with a mechanical fuel pump.
How about the carb hoses?
Thanks! Any guestimates on length?
I will familiarize myself with realoem. I've never had such a resource.
Go to Belmetric and buy 2 meters of braided hose. Enough for engine compartment and trunk.
Belmetric may be all that, but your Friendly Local Auto Parts Store (FLAPS) should have the correct 8x13 hose in stock, unless they are all about 'murrican cars.
And recall that the fabric braided lines tended to get brittle, crack and ... there goes your car. I once took apart two VW engines for a friend's bus. We mixed and matched and got a running engine with nicely cleaned and painted shrouding. Two months later his sister borrowed the van to move her stuff. She "smelled something" on the freeway and by the time she pulled over, the back was all in flames. Hot enough to melt the aluminum alternator support and part of the case as well. Still, some good came out of it: insurance paid him more for the van than we had put into it, though not as much as it would sell for today. We figured that the six or eight inch hose between the fuel pump and carb had probably ruptured, leaving enough fuel in the carb to make a goodly bit of flames back there. Since we hadn't replaced the bulkhead between the fuel tank and the engine, that probably contributed to the carnage. No one was hurt and I don't know if any personal goods were onboard when the fire started.
Steve,
were you talking about braided stainless hose by chance? i looked at Belmetric and i see 7/12 and 9/14 standard braided hose. actually i just looked at the stainless hose and it is 6/8.
No, the black fabric kind.
Steve,
I go with BMW V Fuel 8x13. There is no reason to skimp on fuel line. I'm with Don on the cloth braided line, and the braided stainless is scary because it will saw through stuff if you don't secure it well enough.
Do you guys really have an issue with rubber hoses cracking in CA? I bought a 17 year old MkII Jetta Coupe in Phoenix and every interior plastic clip seemed to be made of glass. The rubber hoses were fine though. I feel like the hoses in the PNW have a good half life. We rarely hit 100 degrees.
Doesn't hit 90 here in Honolulu but a few days a year, if that. But I guarantee you that the fabric covered hoses are dangerous.
Think this way (I know you already bought your hose...) The correct hose will show cracks, if any, and the braided ones which are KNOWN to crack and fail, will not.
But okay, you got what you wanted. Just make sure to check on whatever your schedule determines as appropriate. But I've seen car fires (plural) and they advance more quickly than you can get out and trigger an extinguisher.
I replace mine every couple of years when it gets frayed or stained so cracking has not been an issue. Cheap insurance, especially if you have ethanol in the fuel. Fortunately we have ethanol-free here.
When I got my car it had braided fuel hose on it at least 20 years old and was not cracked so I have not seen any evidence that braided is known to crack more than non-braided. But Don's point is valid regarding visibility.
I love the vintage look, so like anything old school, takes a little more effort to stay on top of.
