do we really need a bypass ?
well here are my thoughts:
i do not know if it is a real need of stopping the wáter passing through the heater radiator, i do not know how much heat would be refrained from entering the cabin if doing this, but it seems to me interesting to try, to keep a source of an average 85ºC beneath the dash is for sure not the best idea
it is not a priority, but i discovered pieces that might make this work conveniently, the process was:
1- i found the pieces
2- i started conceiving the solution
i would not consider bypassing permanently the tubes by linking them together as it was presented by a gentleman living in tropical climate ;-)
but absolutely i would not block the coolant flow as one fórum member did with the help of his mechanic that said "this is the way BMW would have done":shock:, did i mentioned before that i do not trust in average mechanics ? yeah, probably more that once,...
, it is ok with them, but: 1st. they do not have the time 2nd.. the car is not their car, it is YOUR car, it is so easy to bet with someone else´s money...!
i need to be able to switch from one situation to the other, moreover i would prefer to run some coolant now and then through the heater radiator instead of keeping it fluidless and dry
on the other hand i prefer to drive knowing that the engine will not suffer, than being in the risk of blowing the head gasket, stories of 5th and 6th cylinder being badly refrigerated fill my nightmares
i know that younger M30 engines have a tap that simply closes the flow, but those engines are not conceived as the M30 carburetted versión, i can not tell the way the block, head, and so on is built, who can assure those engines are built the same ? who knows the differences of coolant routing ?
what is the effect of closing the hose that goes inside the admission manifold ? i am unable to tell if the coolant circulation through those admission manifolds is made to cool the manifolds or to warm the fuel mixture, so what would be the effect of blocking that part of the circuit ? temperature will increase there for sure,...
the switchable bypass is a very simple solution, the most important problem is the lack of space and the need to find automotive rated valves for a mínimum functional warranty
so i will go the route the real bmw would have done,...if complicate Works just as well why make it simple ?, ha, ha, ha
IMHO
