Window Wood Trim
BarryMW
Malaysia
My right passenger window wood trim is fallin off and l noticed the previous owner just used glue and double sided adhesive tape to stick it on....
Please share and advise what is used to fix both door and window wood trim.
there are several small screws that attach it to the metal window cap - from the back side
Thanks rsporsche!
I will try to remove the wood trim and check if the small screws are missing!
screws
I'm sure that you will use the "search" to find out how to remove the panels properly...
There is a good possibility that the small wood blocks that the screws go into, has fallen off of the wood moulding...the 40year old glue probably gave up from heat and moisture..so the screws/little blocks, maybe in the bottom inside of door panels.
Thanks rsporsche!
Barry,
you will have to remove the door panels, ash tray, the arm rest, etc. before you can remove the metal panel that holds the wood.
