320i shift lever question
Does anyone know if the bottom half of an e21 320i shift lever will fit into the upper half of an e9 lever with the grommets, springs etc keeping it together as usual? Planning the 5 speed conversion. Thanks.
Hi Steve
Brian at Rennsport here in Reno had a couple of shifters when I did mine.PM if you want his cel #.
Tim
Make sure cut the matching notch on the e21 shifter for easy disassembly.
E9 shifter with notch
