Ok what is the secret to getting the oil pan off, I have removed the sway bar, the alternator/power steering bracket, the a/c bracket, all 250 10mm pan bolts, tilted the engine everyway possible, but I can't get the pan inner baffles to clear what appears to be the oil pump uptake arm. The manual says to turn it and drop it down but there is no doing that. The subframe says no. It looks like the only way to get enough clearance would be to unbolt the motor mounts and jack the engine up. Am I missing something?
