WANTED: 3.0 CS/CSI/CLS rear trailing arms/brakes
teahead
aka "Rob"
Tacoma, WA, USA
WANTED: 3.0 CS/CSI/CSL rear trailing arms/brakes
I know, they're getting hard to find, but what can I do? Just bought this 2800 and just now started to look for those elusive rear disk brake setups.
They should look something like:
so in addition to the swing arms, you will need protection plates, discs, calipers, parking brakes, 3.0cs brake proportioning valve. while you are doing this, you should replace the rear wheel bearings, the bushings for the swing arms.
Right.
I have the calipers from an E24 already. I have most of the parking brake setup from my junker E12, but wouldn't mind getting it all w/the rotors.
Acc. to realoem, brake proportioning valve didn't change. You'd think it would going from drum to disc in the rear.
