How does the oil flow in the engine?
What is the flow of oil from the pump to and through the head? Does it only go up through the back head bolt hole past the pressure gauge or does it go up the front of the head also? Any diagrams out there on the M30?
Am curious.
how does it get from the hole in the corner of the bloc/head joint to the banjo bolts?
Sould be close....
I've had that though about various things seen online.
Basically, grab the .pdf, .png, .bmp or whatever format it's in, take it to your friendly local print shop and they should be able to print it any size you want, on an media you want.
But they should tell you (or you'll soon find out) that the resolution isn't sufficient and it'll look hell when expanded much beyond the size you see it on your PC screen.
Different story if you can get a hi-res image...
