A question for E9ers:
I am having some difficulty getting the passenger side door adjusted, resulting in no contact between the windows and the seal with an annoying whistle above 45 mph. The door is rotated slightly outward, and perhpaps a bit too low. I have tried adjusting the hinge held to the body with the allen head bolts, but cannot quite acheive correct position. One of the problems is using a car jack, protecting the door with a small 2 x 4 between door and jack, which imparts a rotational force, twisting the door counterclockwise when facing front.
Any tips on how best to accomplish ?
Also, inside the door is the door mounted attachment, on my car there is the "triple square" bolt used to secure the "tab" to the door. If I have to use that adjustment, does anyone know if it is an 8 mm or 7 mm triple square ? I tried the 8 but it seemed too large (?paint on the bolt) but 7 mm seems not to be widely available, per NAPA
Dana
Dana
