1980 528i parting out
nobrakese28
Hi guys and gals,
I will be parting out a 1980 528i likely next week. The transmission, diff, and shifter parts are spoken for but everything else is up for grabs.
Prices will be cheap, just trying to recover some of cost.
So please let me know if you are interested in anything.
All parts are located in Los Angeles, California.
Thanks,
Marco
I could use the trunk lock if it is in working condition.
Maybe even the entire trunk lid if not rusty.
E12 parts
Hi,
How is the wood strip on the front passenger door? Thanks!
looking for external ballast resistor that is two white ceramic rods inside an aluminum housing. should be over below coil.
thanks!
Steve
Still shows up as a good part number
two parts numbers though. One for manual, one for automatic. Shows up in fuel injection parts.
BMW of South Atlanta. $70 ish.
Here she is. Overall she is in bad shape. Let me know what you want, prices will be low and local pick up is preferred. The vehicle will likely be taken to the scrapper this Sunday.
Pull those aluminum strips off the door panels. They are probably too short for the front door but someone can use them for the rear e9 panels. You may even be able to make two with each side. Place the cut side closest to the trunk.
Looks like the ashtrays match. Also, the door switches for the interior lights.
Alan was looking for a little rubber seal for the rear side-marker.
Still interested in the trunk lock, if you can remove it I will send you a paypal or check with a shipping address in California.
I am interested in the gear shift boot. Worn condition is Ok as l can use it for a pattern. Just need to make sure it is all there including the mounting surround
Transmission mount?
Hi guys and gals,
Is the transmission a 5 speed? Is the steel mount for it spoken for as well?
Ian
