Installing my AC: What holds together the AC console sides?
Wow, never saw that before, another unexplainable change by BMW. Wonder when it changed?
I took a pic with the measurements. Measuring tape starts from the shifter end of the console. The parts CSI that this came from was built in '72.
Same hole in side panel for use on my 2800cs with fact a/c.
Luis's tunnel mount is upside down. Will mount to the side panels through hole shown and also uses mount on a/c panel side.
my 2800cs has the holes in the side of the console and has the mount in the same direction as Luis' also
I peaked in with a flashlight and, I stand corrected. Mine also, are pointed down.
You know what they say. Your memory is the second thing to go.
