Look on the bright side (always)... and never compression test an engine that isn't running poorly enough that you'd consider seeing your banker to determine why.
Compression testing just came up with a pal who got a small ancient outboard motor for which all parts are NLA. He borrowed my compression gage, then complained the engine wouldn't turn over. Of course, the piston was hitting the adaptor screwed into the sparkplug hole. So I brought my hold-it-in-with-your-thumb tester that I got 40 years ago in my aircooled VW days, and we (this time)did it again: low compression on one of two cylinders, didn't even try the other. Also noted a helicoil in one plug hole, so there's no end to how bad it could be/get. He only wants it as a kicker for a small sailboat (he's far too outa shape to row). I told him heck, as long as it runs, it'll hold against the tradewinds, and Bob's yer uncle.
Whatever... if you can live with how the car runs now, it may not get much worse, and what you're looking at, is how it'll be.
This all assumes the original set of numbers weren't someone's imagination or fabrication.
