seal between the front door and quarter panel glass
autowerks
Dallas, Texas
Need help with your knowledge and know how to install the seal between door and quarter panel glass, Thanks
drill out the rivets- then lift out the wing window
then its easy
pull and reset with screwdiver
the rerevit
you can do it in the car
just release the bolt to pull the window
then its easy
the rerevit
I don't think he wants to remove the regulator and window.
Thank you, but I was looking installation on quarter panel glass seal, I if you by an chance know the thread, thanks again!
Auto- Can you post a picture or PM me- I'm in Austin and I have my Polaris rear window trim apart right now. I've done a few of these so if I know what you're meaning I might be able to send some shots.
Peter
Once again, rear quarter window or front vent window?
Well he owned a body shop. I'm guessing that when he says "quarter panel" he means the rear quarter window. The only thing that makes it slightly confusing is the fact that this is a simple seal that doesn't really require "installing".
Autowerks,
Throw out a number...
