Seat rails, anyone seprated them to prepare for zinc coating
eriknetherlands
Netherlands, Eindhoven area
Hi. Just wondered if anyone has seperated their seat rails.
Mine are rough and do not run smootly. So my wish is to fresh them up; tTake them apart and bright zinc them, and then new grease should have them run smooth again.
But how do they come apart?
They only solution I have is to bend open both ends releasing the balls inside. There are also to cilinders, barrels with what seems to be a rubber O-ring on them. I'd like to get them out as well.
Any hints that are less destructive?
Erik
Hi - do not take them to bits, they will zinc plate then as a whole - they will still work fine - I had my xk150 ones done - they were all rusted up big time, with ball bearings in - they came back working fine and all looking new without taking to bits - they also did all my window winders and internal door locking stuff -
I had mine plated. The key is to have the top rail opened all the way so the zinc gets the front of the bottom rail. The zinc will not throw all the way back in to the inside of the rail so you don't want to find yourself with an ugly exposed surface that has not been plated. On '73 and earlier cars there was a chromed plastic cover that covered and adorned the outer edge of the seat rail.
You can partially see the cover here:
RF7lLmPmZNynM_x5K2b1MdAd16-qT_VsV2Ll8yVc1dqn1CaiU9TofOnSt7-js4c3LCUhifi5EfnWvqktZ5VnZPjsakPfwG8rX_kTwwjDxuBAVRPfOdfA2n2oLMM4GLkdzzG1yR_VmtQs__BxV8ql_nijEKxQ_HsRXlHC8RDdZyNt1v3Gc59gyMpkYaGRpiYcatwe4yj9yF1bKLNP6ZlCcjxsD6Gq2oApkTXOhUbuiQhqa5BxITqYVpUOZPmB3-p-hh_vG_hUQ_d7x6FuEL-7yqFdQyByBQlvv6Cpf-hm8kkqWbodhrAHmXpOa1AElo9Bmu6_0tcEeRQo5IA6AYNqimjyzCZJ6TlpoNYgNyQfg-3-lwTqHzuNQ-9LCiXQjAXxCOX_emXjzKK-_bLYL5UxFiOIoQOwBDW--poxkgSsff7T0nt9KQ3U0ioYH7c4gvAdesoxSQSNT51n1KhSKxSJe4qd2iGaVDG3ZHUpbUry3hwnLU3fBvgOqV8P9KOSikLEiDuWGBp7Tvfok3WRjaDB-StS0PUpb4TgHBkAT0MPxhciQUAKkniUGoQgYoVJUKFJLr91RcEsPbY9R3RfHMRKJkoRJtwVX7ML29QHnvIFl8PuahA=w952-h643-no
RXSH7PKm5Q2L6v0C90rKSqGqHD2igAoLYWgPGSGzl6-YZmWJCAMq8e2tjSuZYO0aVC9Q8j0j_S2YW8PptADSCgOp38ghfRe1oOAIx6-hpxvq1xg_9aiPHbiatcZ-X9nIH4kOLlx_r5yZOL2kGG7pkxLLei3Xj3SePhsOYnXlrmqHiijO_6YxKTEGIR_-n9AoHSpsQfIpvhdEmX5Ln_mmhnsOSNsSlzGUSgbTlbzN9JCZB15u7kJ33O743Rh0b1KmRBh0OuWb42guml5WwTrSAr640GkvB5n7kETXhu2DuBfIVDBux1uvVMiygx2myFLQh7I3rKbpf5HM-NLYGorRH9rDm0gfjY04u86Zc0pvlZ73BM0AMguU3fGRuf9OIc5ZinLDYExSQExnchLM12kcCDbQ-HKH0zGSu9S3FMYX20LxTs2KX30ptCcEA4j2Aup99kgQgnyg00splBKsLMz_LQr0U6cPvrZytMJ5-qBEjls630aHBZHsPH2b_R9Uh2QL0Jj--KAOPiE9WsyfQYyW5VaeGyZIURW9u8QXBe58Bd1Ne3jzRForCXaZ0DnEBm08nTJ5ssitoAg9ExRsJh_WmHGi_4wOD7yTtO32CV6Tg8dxB2o=w423-h643-no
right mike i havent installed mine plastic piece yet
which really covers the whole rail so the chrome barely shows
Paul,
Clear zinc really looks best and you don't have to separate the pieces. The bottom of your seat has plastic chrome hockey sticks as finishers and the lower track has a plastic chrome cover attached to floor.
Chris
Mike, what wood have you used? looks great. who did the work?
