I would think the clearance is less because as the 2 metals being measured (top of valve and rocker) heat up, the gap between them has decreased because the 2 metals have expanded.
dear @lloyd
I do not think anyone is disputing the fact that metal expands with heat and that the valve lash or tappet clearances get smaller as the various metal components expand
i am disputing this, precisely
in my humble experience + opinión VALVE CLEARANCES GET BIGGER (+0,5MM) IN A HOT ENGINE with respect to the same cold engine
Here is what my engineers said about this discussion.
This guy does engine programming for professional race teams including a team that got third at LeMans a few years ago.
"My personal experience has been that the lash is reduced when valvetrain warms to operating temperature. I also would not ever call the valvetrain of an old BMW "complex" in any way - that part made me laugh.
Maybe the specific metallurgy of his valves causes them to shrink lengthwise - who knows".
And this guy is a machinist and builds some pretty cool motors. Mostly old school now.
"On the Robert Yates motor I just finished and raced at Road Atlanta, Elliot Sadler used to drive the car. The valves were set .004" intake and zero on the exhaust. Now, ask them what is going to happen when that tightens up, the exhaust will never close. I must be giving some horsepower away. That was aluminum heads and titanium valves but it is much the same though not as much on Cast iron heads.
Now on Overhead cam motors depending on aluminum or iron heads, the metal will grow with heat, valves and head. The best way to determine what you want, figure the desired lash hot, set your valve cold and check it after you run. That way you can calculate what cold setting you need which answers the question".
deQuincey,
I'm just going to stay with what I've been doing for 50 years. I recently sold an M30 powered 84 BMW 533i with 312000 miles. Engine never opened up.
Wasn't even running oil with ZDDP most of it's life. Always used the settings from a Bentley manual.
It smoked a little on acceleration because the valve guides were wearing out.
As far as engine noise goes I would say an M30 motor would be a 6 on a scale of 1-10. 10 being the loudest.
It does have a mechanical valve train and a chain driven cam and oil pump. All of this makes more noise than say a motor with a rubber timing belt.
Be glad to see if you can show us if the valve clearance actually increases in a warm M30 motor. If my motor was in my car and running I would do this test.
Actually I've never thought to measure it and one reason would be how much the temp can drop before you can even get the valve cover off.
The data given in the manuals is for setting a cold engine so if the setting does get larger with heat I'm sure the engineers knew it and knew what they were doing stating the specs.
If you find some more info please let us know.
Gary
Didn't curiosity kill the cat?
As DQ mentions, the manual's spec sheet includes a footnote for setting valve clearances when hot that is larger than when cold. .014" versus .012. Although the manual is hardly infallible, there should be an obvious reason for this recommendation. Presumably, the hot setting is in the manual as advice for professional mechanics, working on an hourly rate, who may not care to charge for the time it takes an engine to cool. A quick look at the owners manual and the relevant Autobooks guide only mentions setting valve clearances when cold (below 95 degrees Farenheit). (From long ago personal experience, I have measured valve clearances on M10 and M30 engines when hot when dealing with reground cams. For the most part, I found negligible variations between cold and hot settings. This was not for the direct purpose of measuring any thermal impact on valve clearances as opposed to making sure that everything was operating within acceptable limits.)
For those dubious of DQ's observation and the shop manual's recommendation, perform your own careful test by simply measuring cold versus hot. In the large scheme of things, the differences are negligible. especially since the vast majority of us DIY'ers adjust our valves when cold.
I tried to offer a lay-explanation by focusing on the various angles involved in the mechanical linkage that controls each valve. Per the illustrations, assuming that normal thermodynamic principals apply, the metal expands with heat although some of it expands at different rates and in different directions, allowing for deflection with expansion. (See bowden cable illustration ^^^^.) But there was an equally plausible explanation in one of the linked sources mentioned in this thread: "As the aluminum gets hotter it expands and moves the rocker arm away from the valve."
The design of the aluminum alloy M10 and M30 cylinder heads suspends and supports the cam and rocker shafts securing the rockers. From the illustration below, the aluminum bosses would likely expand upward and away from the heat source (combustion chamber), thus causing a slightly increased valve lash clearance when hot. Being steel, the cam and rocker shafts will not expand at the same rate as the aluminum and this might explain why, all things being equal, all of the heated metal parts do not result in a decreased valve lash clearance. Additionally, the rockers are isolated from the cylinder head and therefore the cylinder head's heat and are therefore less likely to expand at the same rate as the cylinder head material. (Someone handy with a pyrometer and a spare head could measure the expansion of the bosses that carry the cam and rocker shafts to confirm this theory.)
