... nope, not BMW this time.  But... Honda!!!
My wife drives a 2011 Honda Insight. Awesome commuter car, really. 40mpg and has never missed a beat. It reached 100,000 miles recently so we're in for major service. That includes replacing the spark plugs and adjusting the valves. So I think to myself:
- get 4 spark plugs from the parts department. 4x$10= $40
- gap them: 10 minutes if you're slow.
- Remove the old ones, put the new ones in: 10 minutes.
- remove the valve cover
- Put your feeler gauge under the cam lobes (or whatever they use in that engine) and adjust to spec.
- Replace valve cover
- Sign off on the paperwork.
Total: $40 in parts plus an hour of labor. About $140 or so.
Right?
Wrong.
$530 just for spark plugs and valves my dear sir! Plus the rest of the service of course, oil change, tranny fluid, etc...
Saaaay whhaaaaaaat?????
Apparently, this little 4 banger uses 8 spark plugs, not 4. And not just any spark plus but these new iridium ones at $20 a pop. There goes $160 in parts right there.
Then to reach the valves, you have to tear half of the engine off because everything is packed so tightly in there, you can't reach anything directly. Etc... etc...
A little internet search seems to indicate that that is indeed the going rate or thereabout.
Trying to find the silver lining, I tell myself that at least this is only required once every 100,000 miles so I suppose it probably ends up being cheaper than on an M30 in the long run.
But still.... $530 ???
Right?
Wrong.
