Reassembly of center console insight/pictures needed.
Mark ... they aren't hanging below the bottom of the console sides ... they either stick out past the back of the console sides ... or they flip around and mount behind the side grilles. my car isn't here so i can't go look
They stick out the back and mount to the holes in the bracket mounted to the floor. The slotted holes Scott mentioned. You will need some speed clips (this is what Belmetric calls them) to slip over the slotted holes. The screws will then screw into the speed clips. You can't see them unless you look under the dash way in the back.
Ahh perfect!
Whilst we are on the subject of assembling this portion of our cars, has anyone found a good way to secure the lower dash panel tightly up against the steering column covers? The contour on the front of the dash panel appears to fit nicely under the steering column cover, but when I assemble it using the bracket for the fuse door stop it is no longer tight. (Also, I may be missing that upper bracket above the emergency flashers.)
