Mystery clamp
axco
Norwalk, CT
Can't figure out what this clamp does. It is located under the dash right above the heater/fresh air controls.
The boss which holds the threaded portion looks like it's glued to the sheet metal. Any ideas?
yes, that is one of the clamps that holds the dash in place. be careful loosening the nut, the bolt can break loose from the wood - its set in the wood with resin that can crumble.
when i removed my dash i hollowed out a square in the bottom of the dash and inseted a piece of oak
so it will always be anchored firmly
