inovermyhead
Scott,
You don’t have much choice where to fit the pivot, it has to be structural/strong, going through the sheet metal of the rear window mounting just won’t do it. It also ideally needs to be higher than your shoulder so the belt works properly, obviously missing a b pillar rules that out, so I went as high as I could, strengthened the mounting point with some flat bar in the channel held by 3 10mm bolts to the door jamb. While thankfully I haven’t needed to test it in the real world I feel confident it would do its job if needed, we have some fairly stringent standards here and the engineer who signed it off commented that it was well thought out and executed. But to do it you will need to drill through the wood....
Best. John
Best. John
