Door card blanks
Bwana
Santa Fe, NM
Does anybody have a set of old door card blanks? I'm going to remake mine as they are a little dog-eared and I need a blank to make a pattern from. Low cost if possible, don't need the coverings or attachments. I'd like the blanks to work from instead of taking mine off for some indeterminate time while I make a mock up.
I kind of wanted to play around with the DIY effort. I made a set of trunk inserts that came out pretty well so thought I'd try something else
I believe srennoc here makes high quality replacements, much easier.
the ones from Srennoc are beautiful. i don't think sfdon sells them anymore, best to go straight to Terry. they are beautiful and made out of wood. they have all of the holes for mounting - except the holes for mounting the chrome panel trims. these are made of wood, not chipboard or waterproof panel board
If you're going to make them, why not strip the vinyl and foam off and then you have a template. Its very simple but from experience, match the thickness of the card.
I have a set of original boards, all 4, with upholstery shop redo, not too bad but the upper is funcky
In CO
Send pm if interested
