WTB Zenith lower manifold cover. HELP..
Wes
Tasmania, Australia
Has anybody got one of these kicking around?
Doesn't look like W&N have them. This is piece seats on the lower intake manifold, the rear one closest to the manifold. It stands between me and getting my restored coupe on the road..
@Markos
@Keshav Help :) .....
Believe it or not, that may be salvageable if there is no actual holes corroded thru. Bead blast the part, then use a product called labmetal on the corroded hose connections. Once dried, it gets very hard but can be sanded smooth. The area where the gasket is, just sand it down on a hard flat surface. If you have access to powder coating, get it done, the labmetal is designed to deal with the heat that the powder needs to melt at and cure at. I just rebuilt a set of carbs that the manifold pieces were nit much better. That is what I did and after powder coating, labmetal, it was built up and strong enough to use again for a long time.
  • Like
Reactions: Wes
Hi Wes, I'm your last resource for anything.
  • Like
Reactions: Wes
Hi Wes, on your last purchase I told you I wrecked four CS.
