gazzol
Hi guys can anyone please tell me how much oil pressure a box fresh M30 makes?
Gary
Gary
The purpose of the system you are describing is not to cut the fuel pump if there is no pressure (which it will) but rather to only switch the fuel pump on once there is oil pressure, which is a good idea but the down side is (there always is one isn't there! ) that if the engine gets tired and can't develop enough pressure at cranking speed it will never start at all unless you fit a timer relay which runs the pump for a few seconds when you turn the ignition on.SPEAKING OF OIL UNITS
BILL BOUGHT ONE THAT HAS 4 WIRES AND I LOOKED IT UP AND IT SEEMS IT INTERUPTS
THE FUEL PUMP LINE AND TURNS OF THE PUMP WHEN NO OIL PRESSURE
IM THINKING WHY BOTHER IF U HAVE NO OIL
YOUR TOAST ANYWAY
AS ITS ONLY THE OIL PUMP THAT CAN DO THAT AND THEY NEVER FAIL
OK
