You’re right there @jmackro, there off to the side. But I like where his head is at and maybe able to bend the tangs on the fork 90* and see if they’re hard enough to turn them.I don't think any of the tools pictured would grasp the bezels on the Mercedes 190 dash:
- The tools pictured have pins that go into holes that are co-axial with the armature of the switch (e.g., perpendicular to the plane of the dash face).
- The bezels on the Mercedes 190 dash have holes that are perpendicular to the armature of the switch (e.g., parallel to the plane of the dash face).
Circlip pliers?
I use circlip pliers to remove the style of bezel with holes that are co-axial with the armature of the switch (e.g., perpendicular to the plane of the dash face). A pair of circlip pliers with the tips bent 90 degrees (like the photo below) works great for this purpose.
As Rex wrote, if the tips on pliers like these could each be rotated 90 degrees, so that the pins face each-other, they might work on the Mercedes bezels. But could they be opened wide enough to get into the opposing holes?
