SOLD Weber carbs 32/36 DGV, linkage, airbox
jefflit
Los Angeles, CA
Purchased 2/2015 and used on my car until disassembly last Nov. Not many miles. Worked perfect but I didn't love the manual choke (never got the cable working smoothly). Includes carbs with intake manifolds and custom linkage that worked perfect. Also includes cast aluminum tops that adapt Webers to stock air cleaner. Paid $400 for carbs alone. Offered at $250 for all.
Also for sale is the stock air cleaner assembly. All clasps there and working properly. Original patina. $75. Filter elements free ;-).
Also available are the Webers I removed from the car. These have manual chokes with idle circuit cutoff solenoids but sticky secondary shafts so need rebuild. $50 for the pair.
Old carbs:
Thanks to member Tom, I have corrected the post to note that the old set of carbs are also manual chokes. I had incorrectly assumed that the electrical spade on the side was for electric choke but I am informed it is actually a solenoid to cut fuel delivery when ignition is turned off.
Hi there,
Did you sell these Webers?
Regards,
Bill
