Today's what is this...
dave v. in nc
North Carolina, USA
Every coupe has/had two of these, left and right. Not a Walter Gropius study for the new Bauhaus library. Not a shift knob in the rough...
dang
Administrator
Rocklin, CA
Hmm. Based on the shape I'd say it wasn't a wheel chalk because you wouldn't need two angled options. Something to do with transportation, maybe wedged between the springs for some reason?
i believe that Keshav is correct. i drew the side armrests in autocad to rebuild mine. and the top piece looks very much like this
dave v. in nc
North Carolina, USA
Very good Keshav!..and rsp! yes, the top back corner of the rear armrest...strangely complex for a corner block...the whole structure, and the foam are typically anal, I meant German... wonderfully over-engineered. I just de-assembled a rotten armest, and if you haven't seen one "naked", it's pretty interesting...
Keshav
Germany
I’ll give it you Dave for coming up with a tricky one though..... I was just lucky, took some pondering!
Keshav
Germany
And whilst we are at it, our friend Christoph (whose pic I stole) is making these brand new armrests with the seat belt slide as found on the face lift cars (74 onwards). I remember having a real hard time finding them at all before he started.
if anybody is in need, i can publish a pdf of the autocad drawings for the reconstruction of these rear armrests ... well first i would need to get somebody (Stephen or Alan) to create the pdf from the autocad file. its really not hard to make these, especially if you have the bigger pieces of solid wood in decent shape as its usually the plywood that breaks. mine do not have the seat belt slide cutout, so the drawing file doesn't have that feature
dave v. in nc
North Carolina, USA
I had considered trying to make a few (friend with a cnc router), but not sure what the market would bear..what is Christoph's site name? No reason to re-invent if his are reasonable..His parts look good, and even appears to have moulded foam.
Yes, Dan, clever Teuton packaging...
Keshav
Germany
dave v. in nc
North Carolina, USA
I think I am reading that this is a refurbished/restored original, which explains the foam. Nicely done. And thanks for the link to his site. If I consider making some, I would just do the wood parts, and let the end-use upholsterer do the rest...
Reusing the sculpted foam is important .. otherwise you are spending a lot of time getting the shape correct. you have to be careful removing it though.
dave v. in nc
North Carolina, USA
100 % agree...the one I de-constructed yesterday had rotten wood, but still had use a sharp knife to get the foam liberated...Once the cover (fell...) came off, I could see, as you say, that the foam was the only thing salvageable (other than the window switch).
