mmccusername
I know-- rare!
Thanks, Michael
Thanks, Michael
I know Steve has one and likes it, but what is the advantage to the VGS over the Korman manifold (says a guy who has a Korman manifold)?
As the guy who bought one from Germany in an instant, I can tell you it is still on my shelf - long from being installed on my car. I am not 100% certain I will use it - I am at about 70% probability. And for me, it also depends on applicability of finding another option (a Korman manifold for example). My current Redline manifolds are clearing the t-stat housing, so I think we found a good housing. And I have a tii booster that I am considering using, which alleviates that clearance issue.One came up in Germany recently but was gone in an instant.
As the guy who bought one from Germany in an instant, I can tell you it is still on my shelf - long from being installed on my car. i am not 100% certain i will use it - I am at about 70% probability. And for me, it also depends on applicability of finding another option (a Korman manifold for example). My current Redline manifolds are clearing the t-stat housing, so I think we found a good housing. And I have a tii booster that I am considering using, which alleviates that clearance issue.
I don't know what my point is - just rambling...
Yes, well, I guess based on my rambling there is a solid 30% chance of that.I thought your point was going to be that you were going to sell me your VGS manifold!![]()
Yes, well, I guess based on my rambling there is a solid 30% chance of that.Let me ponder my alternatives.
[/QUOTE]In my opinion, if you don’t have to use the VGS manifold, I would use another. I’m sure that @Stevehose can elaborate, but the depth of the carbs aren’t in alignment. So things like bolt on air boxes and other filters can be trickier. The things is that if you don’t use that manifold then you need to worry about the t-stat and the booster.
I personally like the idea of a one piece manfold, but for me that is still just a concept. I haven’t proven that I can bolt the whole thing to the head with the carbs connected and throttle balanced. It works on my bench but I have access to the studs.
Not the depth, but the spacing, they aren't even because of the first carb t-stat clearance. It was available with an airbox with brake booster cutout. Not as cool as Alpina, but VGS was another engine tweaker back in the day and still in business.
I've taken the entire carb & manifold assembly off the head in one piece a couple times. I have a special ground down 13mm wrench I use for a couple of the hard to reach nuts as Chris mentions. And a couple different socket extensions.
I see this as a big advantage of the one-piece manifold. Would you agree or is it no big deal?
