Triple Carb Intake Manifolds: Pics & Specs
Gruppe,
Could we create a gallery of the various triple 'manifolds' and set ups?.
I'd like to compare /contrast the various set-ups and solutions with various boosters and T-stat issues.
VGS:
nNIc3sksW9V7lZnGG8pFuRfK2RsUOgPLjHZ6bCqzNn6HLb94DUrGz-bmXund8Kow9ndguZJ245sMGGw0b0aTOq4qBqtSUoEr7PZ_kYYDBzzW_QNURr1xEmKvcflPqBg--cn5oy_j1-ihCScj0wMIddftr1gVcILkP2ZeG_Jcf1pQgRwfFI7sD347obF5wVeEtMEypyAbsPcFDTOA4PBr2AMXxctqH0EoOWFnUnYBNM27W-s0u5juGq613lI4e_vNsxotDMKKtPoLzDGAs89cCdzHLETSxlS0045nbK_tL2pkieymfK2oqwpebzL-8WK-HhUWlPTkAI1mBN3zICgSJ1ACxhwzOd9rM2EOlhmhE9M8XdsmOKD-iDQaYzJtAV0yDjOTna-ZTKgmlmWGD_ysk-ReiZlg1o-1JeFIou64IceP-jx4F48eVRK2dP5Pxkw5H88jzHGkA8VP-pb9jt27oBTvOUZ3SObxoAQpPR2EzjOLMKF51UZboZe05A8miB8hdCb1H4c7y4Qi3HpLnDc841l2kDsLaYqsFtpCdTfdnRZBBmJgwP7ZmpI23rsUFcLFlwzqOKUKMEayN17qVJ5Go_ZEil_Ct-DvPyWFOa5T7h7WBPCrAsZ0FeJhYAYLA4X_AeZ0o7p3LQYeJaMIk5AH4A2rVDd5u6mM67wyv2s0JFYY3s-pAlIYsg=w1042-h781-no
FRSValJybdtAPa3Woa7os5aOYbMBHqSPQVsrDqnPT7UgS6ZSXrgI0YqBAQUMMjKoohCUvhvAfjXIa0qL2kx2BbG_LLN5vCZe2Lien_FMLeS5erGVhjkCWV5lHy8ivpzBzyPWa1cPf6hj2OvxS8wvED1mq4G6I7TbHHpQFYfCRuALBt-X6ELzCJnR1ZLjXTmUXJzFJx7QJVYJCAW-GC1F8f2i_sPEBCOSBQ8uxK4QRv6nck_ZqDKIVEuwZQpYxCFTiCIceRtiTa24wQr2zJJXu5hNEyUiJUiRQRTLPFddlM3Yt7ehe_uqHaJHnzFKqvYwS48fOpPszST5TzFL7JopYphfF5_UAuRZ9fHPfKyxhNuLQOZMsFotRYE-cL2632dDp-1-ZYry6g8hgM-PwQcN0W7ChyV8AoJ5DQDJtL4A6tZLxf5mLaVQGmD7Ai0deyfMQPg0MVata7Gu9VlTfd9DzPclXLm5ncNdwp1z118YGuSNQGPPB66rJIIvufnMRPqIwUZNMB6FtgBHI0j2nUuXZGHpFUrO4TUXnCEkSf4OXoWrsWlb-JaEWF6NXyUDQmzqVsQGO5gGdZxLGUgnWSkWCTitZ6t315Ya39nwh9JJ5_330RT49YdJVPMEnVdeRNstZWpJbVwJdgC2cB2lLd4ENbEX4w26iMvumlso0_wc0bzWpoUe358dRg=w1024-h768-no
t-UKCiQRyNckTgJ9BfoCxXaGflm2oqjZG7LVETSTLK2ATo-mWgSm1aksT2pDAo0GedOFTn7XLxBi8nFqmtOI7V6cKlb59NjkNXU-c3_xxmj85Dckimzo6xCuKnlwcbCbjJpsc4uFELkhl5A0zlY5O6e-apGPOT-J02CsEqOPasJppO7jCTnXTSxKkQCOx2ZdEOomWOr0y4kG9AIcIt_qCVHpAZiaI1ChlFT1d3rNmLgzCxb80oG7WQnJJjkz7I48pQBNjmjk9kBTHVBS-Imec4iZiHqKxfOs2KFJg_cMc9J12Jqyy47JloLimjHkNIVIpxh9or6b6JiQZFSJzbdLqomHq-zqkacnoliQ4w4VQRfP57sZSdLY0vq9cfI0ZwJswjmX4ACgTyy5h4__kckZaWfovltDw8Ypf3VlkUr7OGtNuv1NUfHmYagb-OZmn6gtjciJzproz631WqpbgaOQg5opvc8LXAuwJSb30jG2yXoptSLPazqRjNnW8oD8Mn8quPWVwg38VCiTIQTNere1xkB8sqjrKZJEBue3McCf1EUd-sYuBOhH9ftZ55GEjp_2HPR0SZ7xW9UzeQSEhB1RW9OeiwgpJiBIKFg0dGg25wyjoj7aScwzvuQOWqXSjAmxBj3eoY7VyFmWOMVdipZWcESLKFryzUilj5yvRoskcXQWX7lonNTomw=w1042-h781-no
Gruppe,
I will be re-visiting this conversion in the future and have seen different set ups. I'd like to avoid the brake booster swap and have heard of the early boosters (thinner?) create a different scenario. I have a 3x2 set -up on the shelf that I'd like to identify along with my booster and T-stat.
thank
Hi @shanon,
I moved this to general to avoid hijacking a WTB post. My Korman intake is free. I just recently measured it for a friend, but didn’t post pics. It is on my workbench so I’ll snag some pics and measurements.
@Stevehose ,
I copied your post also and quoted Shanon to add context. You posted first so it stuck it on top
of his...
Excellent and thx.
Ohmess, where did you source the Alfa GTA horns? Those just might be my ticket ;)
Using a stock E10 booster and the intakes are angled to clear the T-stat housing (can't remember the manufacturer of the intakes, british company).
3D printed stacks about 35 mm long.
those resemble the LTEC type... but i'm not sure .
Myself have the Dbilas ones… had to change the thermo housing.
Mine are Mangoletsi! http://www.mangoletsimanifolds.com/index.html
Mangoletsi makes great stuff. Their cable throttle linkages and EFI kits are well-known in the e-type world. Didn't realize they made e9 manifolds...
Karzunpartz intake manifold installed in the 80’s. It worked with the original thermostat housing but I had to add a spacer when I recently replaced it with a newer one. I cut a 45 degree angle off the bottom of one of the air horns to clear the original brake booster but eventually swapped it out with a tii booster,
Reply to Shanon I posted in another thread by mistake:
Hi Shanon -- I got the repro Alfa Romeo air horns from a company called Corsa Velocita. I like them a lot, but I have had two minor issues with them. First, the outer rim of the horns is so large that they hit one another if you install them straight out from the throats. If you look closely at my picture I have each horn angled just a little. The other issue I have had is that I've lost two of the air cleaners while driving. The filter element goes all the way out to the edge of the plastic frame that goes over the lip of the horn, and is compressed between the frame and the edge of the horn when you try to install it. Sometimes they snap into place and you know you have it, other times it is not as clear that it is properly seated. I recommend buying a pair of spares if you go this route.
Resurrecting an old thread with a question about the Karzundpartz manifold.
I have one and am trying to determine what size and thread this opening is. It is the smaller of the threaded openings on the three pieces.
It will not take 10mm thread chasers (1.5, 1.25,1.0). It will start to take an "1/8 NPT27" tap, but only just at the entry point and for a couple of turns.
I suspect that it is 1/8NPT and I will just need to re-tap the opening, but before I go down that path any input is helpful.
Thanks.
Thanks.
Check 3/8 - 24. I have the same kit (not yet installed), but I took out one of the spherical bearing bolts and it's definitely 24 thread pitch, and seemed to thread into my 3/8-24 die...it got tight, but threaded on.
Lan
Thanks.
Lance,
I could take out one of my bolts to very if needed.
What thermostat do you have? If it’s a newer one you will need to add a spacer.
