Thinner E9 radiator?
COUPE9
Maple Valley, WA
A while back, I added a clutched fan to my coupe, and now (under braking), the fan SLIGHTLY grazes the center seam on the OEM radiator. It's only a matter of time until I shatter the fan, and blades go through the hood... ...maybe not THAT bad, but you get the idea. I was thinking about replacing the motor mounts (in case they're a bit loose, and allowing the engine to shift more than normal), but was also looking to drop a new thinner radiator into it. Would love any insight on what to purchase (and from whom). Thanks in advance!
adawil2002
Brunswick, Maine
There should be a clip on the fan nut to prevent the fan from coming loose. wonder if your fan is missing the clip.
I have a triple core radiator which is the same thickness as the stock radiator. If anything you want to increase the cooling capacity not decrease it.
Do you know when the the last time the engine mounts were replaced?
Mike Goble
Fairfield, CA
It seems to me like you've opened up a can of worms with the fan. Perhaps taking a step backward would be better. How about a fan that doesn't come so close to the radiator?
Ohmess
I wanna DRIVE!
Aiken, SC
If your motor mounts are questionable, change them. They are relatively cheap.
Check the four rubber mounts for the radiator and make sure they are intact, and while looking at the upper mount on the right side, make sure the bracket on the right side is not loose. The radiator should not be easy to move by hand.
I happen to have a thinner radiator, but I can't point you to a vendor. I bought the radiator from SFDon who bought a vendor's entire inventory and sold off the excess, including mine.
sfdon
sfbay area
How about customizing the radiator rubber? Takes 5 minutes...
sfdon
sfbay area
Pic for you to offset radiator forward
Wladek
Gdansk, POLAND
It's more complicated than just rubber mount cut, but fan mount, part that goes into the fan clutch can be also resurfaced couple mm in marked areas; after resurfacing it will go deeper inside.
m_thompson
Rhode Island
That is on my to-do list to get a little more clearance.
tochi
In addition to the motor mounts, the transmission mount can be equally important to avoiding fan-to-rad contact. This subject has been indirectly discussed in other threads, e.g., https://e9coupe.com/forum/threads/edges-of-fan-are-torn-up-and-radiator-not-looking-to-good.31458/
i did this some years ago,....
see posts #27 and #47
this is how it looks like, RH original, LH modified
Sven
Seattle
Drew - I have also been able to get a little more space by having the radiator core soldered as far forward on the side tanks as they will go.
