Flywheels - Interchangeability
dj_efk
South-West UK
Word from my workshop: My flywheel is at the end of it’s life due to deep scoring on the clutch friction surface, I need to find a replacement.
From RealOEM, I see there were two versions: D=240 X 27 (part no. 11221270286) and D=240 X 33 (part no. 11221706577) - I assume the difference of 6mm is down to the thickness of the flywheel (?).
I may be Interpreting what it’s saying incorrectly, however it seems to suggest the latter (thicker?) part superseded the former - hence they are interchangeable (and hence the clutch parts etc. will fit either).
Any thoughts welcome here, as otherwise the part I am assuming is fitted to my 69 2800cs (240x27 - I can get the workshop to measure it) is going to be very scarce!
On the other hand, if they are indeed interchangeable and hence I can use the 240x33 version then that’s a little easy, as this was fitted to some 2.8 and 3.5 5 cars E12/E28/E23/E24 built before Oct 84, some E32s build before Dec 87 and also some E34s built before April 88 - BUT my question would then be this: Wouldn’t the swap affect the clutch biting point, as the geometry of the actuating mechanism will change?
Honolulu
Honolulu Hawaii
The realoem link illustrates the flywheel for an auto trans car, which yours seems not to be. I assume there isn't another diagram for manual trans cars, since such need not be illustrated. The fiche isn't an assembly diagram, just a sketch of the rough positions of various parts, with p/n's.
The geometry may not change, since most clutch components are bolted to the flywheel. I wonder if the clutch slave was mounted differently though, or one version used a longer pushrod. Some diving into the fiche may reveal that.
dj_efk
South-West UK
Just looked at all the clutch mechanism pages for the car and can’t see any such variation so I assume there is none.
pat cooks
essex
The clutch slave has a long travel and can take up the difference, very early cars used a ZF manual gearbox, only ever seen one, not very nice gearchange and no parts available, later cars from 1970? used a four speed getrag with circlip mounted slave cylinder and a different release arm, later cars, 1974? used a bolt on slave with a different clutch arm and pivot point on the opposite side of the bell housing, I seem to recall that the early pivot was steel and pushed into the front of the gearbox with a clearance hole in the bell housing, later was a plastic pivot pushed into the bell housing, all are interchangeable with a bit of thought and maybe access to a 4" grinder, there are also different style and lengths of release bearings, needs careful assembly and a good idea what looks right regarding angles, travel etc. all above from memory, beware........
dj_efk
South-West UK
Pat,
My car was built in March 69 so is indeed a very early car with the ZF box. Gear change is actually quite nice and precise (to me anyway)
That said, I’m now installing an E12 528i 5 speed in it, so given the the clutch kit is matched to this rather than as per original spec, I probably want a thick version of the flywheel.
Have you got one you can let go of with a good friction surface for the clutch?
Dave
dj_efk
South-West UK
Update: I’ve found a source who can supply an E28 flywheel but I feel the price he is asking is poor value. Should anyone in the UK or EU have one they can supply me at a reasonable price, please PM.
