Thank you Luis.They don’t. The 928/944 sender has the resistances as outlined in a post above. Low resistance(10-15 Ohms)=low pressure(0) and high pressure (5bar)=~180-200 Ohms.
With power on but sender disconnected, the gauge reads 0. When I connect the sender it jumps to 5.I would still be curious what resistance (if any) makes the gauge register zero bar. E.g., what it would display with power on, but the wire to the sender disconnected. And what the gauge would display with the engine running and sender connected. It's possible that the gauge is simply bad or way out of calibration.
This then sounds like the gauge requires a different sender. Plain and simple.With power on but sender disconnected, the gauge reads 0. When I connect the sender it jumps to 5.
I will reinstall the sender today and test it with the engine running.
While that looks like a 928 gauge (except the needle is white, not red/orange as in the 928), I can't vouch for how it has been mounted and wired in that instrument pod. Nor did I read that he tested the gauge by feeding a verified resistance value other than infinite/open, so can't say if the gauge is truly working as it should. But I can assure you that all transaxle Porsches (and many 911s) use that sender, up to the 928 GTS where they use a three-pronged sender.Luis: Assuming Bo really has a Porsche 944/928 gauge, doesn't this contradict what you wrote in post #20? Is it possible that some 944/928 gauges work on the low resistance = high pressure reading principle?
I still would test the gauge to verify its function without the sender, or the wiring to it. I once had one of those gauges acting weirdly and it was a pinched wire, intermittent and with varying resistance, to ground between the sender and gauge.The electronics in those gauges is fairly simple. I wonder if there is a way to inverse the movement of the needle. Something like x1 = 1-x after normalizing our 10-185 ohms scale.
Maybe there is a little adjustable electronic converter/remapper I could add just before the gauge. It could also be used to calibrate the gauge to the sender.
Take the 200 ohm potentiometer and hook it up in lieu of the sender. What do you get? Then do the same directly to the gauge, without using the in-car wiring. What do you get?
Bmachine said:I wonder if there is a way to inverse the movement of the needle. Something like x1 = 1-x after normalizing our 10-185 ohms scale. Maybe there is a little adjustable electronic converter/remapper I could add just before the gauge. It could also be used to calibrate the gauge to the sender.
Thanks for following up, Luis. I have not found the final answer yet. However I have a suspect.
In order to test the validity of the wiring and sensor, I bought a new VDO 80 psi cockpit gauge. I hooked it up with the same setup in the car and sure enough it works exactly the way you expect it to. Showing Low teens at warm idle and between 40 and 55 at high revs.
So the issue is definitely either with the Porsche gauge or with the conversion that was done by a friend of mine to incorporate it in the coupe gauge cluster.
That part I still have to investigate. It involves taking that gauge apart which I have not had time to do yet.
