1970 2.8 engine with Webers, Rear complete subframe, extra non lsd diff
Gary Waggoner
San Clemente
Engine out of my 1970. It ran great with the Weber carbs and is complete with powder coated air cleaner. No accessories included and no harness. $free
Rear subframe out of same vehicle complete with drums and non LSD diff. $free
Non LSD diff from 1974 $free
Located in San Clemente, CA. No shipping.
Someone might want the air cleaner with the early band style clips, the head with an early casting date, especially if the oil sender is mounted low in the rear unique to 69/70ish M30s, Zeniths and manifolds, valve cover and cap, cast exhaust manifold covers if there, etc.
Was saying the same thing. I'm sure that someone wants/needs the Webers. The red oil filter housing. Jay would buy the power steering pump. @Luis A. was just looking for an early valve cover. The bits and pieces on the engine are worth more than the whole package, which as @Gary Waggoner has shown - almost worthless.
@Gary Waggoner - if you can post the ratio on the diff. Someone can always install the LSD if they have a matching case but not the desired ratio.
I would think someone would want that brass expansion tank.
Too bad the 2.8 is so unloved. It has higher compression than the US 3.0, and is quite rev-happy. I am sure all those parts are going to good homes
