Before you sell your Walloth rad better check to see what it costs to recore these radiators! In WI I don’t think the extra sensor to trigger the electric fan is needed and I don’t have that here in CA.
A brass/copper one you know fits is best- except you want a later one with the fitting for the temp sender at the bottom
That sensor was introduced on MY 74 coupes and later models.This is very interesting. My original radiator (or the one that was in the car) does not have the lower right sensor port. But I also do not seem to have the second wire for the aux fan. The new W&N radiator I have is the one Don links to above. The mystery of what to do continues.
"IF" I were to drop, say, a later model injected engine in the car (just thinking out loud), would I want/need this lower sender port on the rad?
Hello Jesus!
The options-
e9 starts with a second wire to the temp sender for the gauge in the thermostat housing to a small module on the passenger inner fender that operates the auxiliary fan.
e12, e24 and e9 late and e3 late Models get a Sender at the bottom right of the radiator to operate a relay for the auxiliary fan
17111121295
Radiator with connector for temperature switch for all models with manual gearbox also for cars without air condition with approx. 25 higher cooling rate compared to the standard radiator you need 1 for 1 car
Radiator with connector for temperature switch for all models with manual gearbox also for cars without air condition with approx. 25 higher cooling rate compared to the standard radiator you need 1 for 1 carwww.wallothnesch.com
an option for a radiator with no opening for a sender is a later “A” Thermostat housing with a 91* sender
We use a 91* C sender / switch if we go to tstat housing - perfect for keeping engine from going over 195* F
Part number 61311364272
12 bucks
We always take power from a switched source and add a fuse.
The temp gauge sender used in 1974 to actuate the fan was a BMW idea.
Ah yes, that is a good upgrade. Is there a specific model/size that has become "the one".Another comment on this Stephen -- replace the fan in front of your radiator with a SPAL pusher fan. Much more efficient and better air flow.
