CadillacGreen
- Messages
- 245
- Reaction score
- 23
Hi,
I am a fairly new CS owner that is attempting a tune up on my dual Zenith carb 3.0 CS with AT. I have worked on lots of old cars in the past, but am a bit stumped and am hoping for some input from more experienced CS owners on my issues.
Car was exhibiting low idle problems at first, idling around 500 and normally dying at stop lights with A/C going. Before I touched the carb settings (being familiar with WCFB's not Zeniths), I felt it best to perform a tuneup, etc.
Pulled the plugs and have definite fouling out of the plugs. No ash, just black, sooty and, in one instance, the smell of gasoline. Both 1-5 were like this, 6 appeared reasonably ok. I should also mention the gaps on the plugs were around 34 and am a bit concerned about that as engine was rebuilt approx. 4000 miles ago by Autohaus Exec in Burlingame, CA. It appears as if the carb may be running too rich.
So I went and had the carbs rebuilt by a local vintage import shop. When I got it back, I went ahead and replaced the plugs. The coupe seemed to run better, but still having issues. I replaced the points, which were pitted, with a new set and gapped to 16. At this point, I hooked up the dwell and got a reading of 25, which is, obviously, lower than normal. I shortened the gap and eventually got the dwell sitting at 36, but this made the point gap around 12, which, to me, is WAY too low.
I then took it for a drive without adjusting the timing to see what difference the new points made. The car appears to be bogging down going from start to around 20 MPH (e.g. worse than at 16) so I went ahead and reset them to 16. I should remark that I haven't touched the timing yet because I didn't want to until I was positive about this dwell issue. Dwell reads 25 again with the regapping to 16.
Anyhow, I checked the coil and it appears to be fine and I have checked all the wires and they appear to be fine in terms of firing regularly so I would assume the cap and rotor are within reason.
I turned up the idle to 950RPMS with the dist. vacuums capped as well.
I should say that I live in Las Vegas and today it is over 100 so I am not sure what, if any, fuel issues could crop up at these higher temps.
I did notice yesterday that, shortly after starting the car, it felt like I was getting vapor lock almost immediately as the car died and I had to crank several times and floor it to get fuel flowing.
I am really trying to get a handle on how much of this fuel or ignition. FWIW, I do have receipts for work done on this car back to the late 1970's/early 1980's. I am the third owner.
Any thoughts?
Thanks in advance!
Any thoughts?
Thanks in advance!
