I flushed the entire brake system. The fluid in the reservoir was like strong tea so I suctioned  it out to avoid pushing it thru the rest of the system.
Then I bled the lines with a very old Bav Auto pressure bleeder. I also put a vacuum bleeder on the nipples because it has a large waste fluid container that can do a couple car’s before needing emptying. Plus, the vacuum prevents leaks at the nipple keeping everything nice and clean.
Anyway, here is my point: The PO used a mechanic who alternated brake fluid colors on each flush to make it easier to tell when the new fluid had reached each caliper. What was in the system was faint blue Motul. The fluid I got out of each caliper had not darkened at as far as I could tell. I suspect I might be ok changing the fluid in the reservoir every two years and the lines/calipers every 4 years if I don’t drive it.
