:evil:
You describe the unwanted symptom as a stumble and hesitation. Is this really a highspeed misfire or cutcut?  Or is it more like a flat spot where the engine continues to run but essentially runs out of power?
Hi Mercury,
yes it is a flat spot rather than a hesitation, it still runs and revs up slowly but the power is gone.
My first reaction is to agree the high speed flat spot or hesitation is typically due to a lean mixture condition. This could be due to inadequate fuel supply
but this does not rule out an ignition issue as simple as a defective rev-limiting-rotor, plugs with an incorrect heat range (usually too hot), a weak or defective coil, plug gaps that are too wide, or for standard Kettering ignition, a funky condenser (they don’t last indefinitely.).
I had a look at the rotor and it is fairly new but I will swop it out to make sure, same with the cap. I will also use the original type plugs to try and eliminate this. I have pertronix installed so no condensor but the coil is a higher performance one without a ballast resistor.
Your first post states the pressure was 26-7 psi and now it is at 32psi. Is the difference due to different gauges or did you adjust the fuel pressure regulator? (I once dealt with a slightly different regulator - from a different vehicle - and it would change pressure readings if the fuel line were deflected enough to slightly change the regulator’s position. This shouldn’t be the case, but we repeated the experiment enough times to warrant replacement.)
Yes the fuel pressure gauge was faulty so I have now changed it and it is ok, tested with two gauges.
Fuel pressure is a good indicator of your fuel system but it does not guarantee volume. Only way to test that is measure the pump outflow. You mentioned the thimble screen in the pump inlet and the tank pickup. What about the filter (usually found under the battery tray? Can you blow through it with minimal effort? (I doubt this is your problem, but anything is possible.) Along those lines, is it possible you have some occult water in the tank? As unbelievable as this may sound, I know someone who inadvertently managed to pump diesel in his Jaguar's tank.  The engine ran fine until he pushed it.  Perhaps very unlikely, but fuel contamination might also account for a high speed miss/flat spot.
I did also change the can type fuel filter, I am fairly sure the pump is working well now.
Next, you mention swapping the ECU. What about the other fuel-inj. related electrics? I cannot say these suggestions are high on my list of possible culprits, but a Pressure sending unit that is on its way out can cause erratic operation.  Similar results could be caused by a loose connection to the temperature sensor II (under the intake manifold and to the right of the auxiliary air valve).  A worn or maladjusted throttle position switch can also be responsible for hesitation and cutouts, although this generally occurs during low speed operation and acceleration.  Finally, do not overlook a bad ground strap between the engine and the body. As a very brief overview of the subject, review this thread:
http://www.e9coupe.com/forum/showthr...?t=2879&page=2
The temperature sensor could be worth checking alright. The TPS has been checked and is ok. I will put another MPS on it to check that this week but I checked it not long ago and it was fine.
I touched on the ignition issue earlier and most of these issues are dealt with as part of any minor tune-up.  In any event, I would carefully examine the rotor (especially if it is a rev limiting type). Regarding your distributor, if it is a typical Csi D-Jet affair, it actually retards the ignition timing at idle.  However, it should hold a vacuum and if it doesn’t you may have a vacuum leak and a source of a leaner mixture.
I sucked on the vacuum advance and it moved inside the distributor housing so that seems ok?
You mentioned retarding the timing. I am not sure why you did this, but if you use a timing light, that tool could be helpful to insure that your distributor’s centrifugal advance is functioning properly (not sticking and/or reaching maximum advance within specs). The mechanism includes two moving weights (requiring lubrication), and two springs (that may loose their tension or even break).
I retarded the timing as she was pinking and I thought that when the distributor was advancing at high revs it may be advancing too much causing the flat spot.
As noted by others, if your coil gets too much voltage due to a bad ballast resistor, or if it is toward the end of its duty cycle, or if there is voltage leaking/arcing from the terminals, this may result in production of a weak spark. Some have described this symptom as like a failing fuel pump. Hint: if you have another coil hand (as you did with the ECU), try running it. Who knows, by doing so, you may discover a loose connection, corrosion etc. where you never thought to look.
I will try the other coil but it is a standard type so will require a ballast resistor right?
End of random thoughts. . . .
Many thanks for the ideas MM - I fear if I don't solve it soon I will give up!
