well, normally this opening is not in direct contact with water. When you look up inside your wheel well, you should not see that opening. There is supposed to be a plate with a seal (located between outer fender and inner wheel house structure) which prevents (but not very effectively) water and stones to enter there. Walloth and Neesch still sell it.
Schottblech im Radhaus vorne rechts für alle Modelle und Baujahre passend wird 1x pro Auto benötigt
Schottblech im Radhaus vorne rechts für alle Modelle und Baujahre passend wird 1x pro Auto benötigtwww.wallothnesch.com
Google "Schottblech BMW E9" for some visual clues.
also covered here:
Front Fender Inner Cover
Does anyone know if item #9 is bolt in? And if there is a gasket that belongs in there with it? Item 9-41141814035,6 for left and right side. W/N calls it an A post cover. Any help or potential used ones out there would be very appreciated. Thank you!e9coupe.com
The lower plates behind the wheel well are 51711813031/2 and they are below and behind the rat hole. I have vacuumed out a bunch of dirt today. I am definitely going with the Lokari Liners.I don't think he is referring to the space behind the covering plate on the fender (part #41141814035 and 36), but rather the cave opening that is open to the wheel well and all the crap thrown up by the tires.
Thanks, I read that the Wurth product is the best to use.Before you install them, spray them with rubberized undercoating so they aren't shiny aluminum.
I have vacuumed 5 pounds of sand and very small rocks from both sides.
Highly suggest Lokari fender liners to mitigate debris getting there & in the catch-all at the rear of the front fender.
Inner wings, front - BMW 3.0 CS / CSi / CSL Coupé / E9 - yoc 68-76 - Industrievertretung Hanna GmbH
BMW, 3.0, CS, CSi, CSL, Coupé, E9, inner wings, wheel, well, liner, Lokariwww.lokari.de
