I wasn’t able to find the plastic tube for mine. It was cracked and I was also not able to repair. I ended up buying a brass reducer with a small pipe coming off the sending unit and a larger pipe then connecting.RE: eriknetherlands
So can that little tube be purchased new?
RE: eriknetherlands
Don needs to double check, that might be an l-jet coil like is on my e12 as the label says transistor.I'll take the pretty silver one please!
In that case, I'll pass on that one so someone else can use it. I will instead take the blue labeled one next to it on the right. Sorry for the confusion. Thanks for the sharp eyes Chris.that might be an l-jet coil like is on my e12 as the label says transistor.
I have no direct experience, but the original Parts Manual seems to agree. Though it does suggest that there might have been two versions for the 2.8 models.I know of no difference between model years senders for carbureted cars.
Csi senders are different- anybody want to add to this?
