By collection just to be aware I do mean 70s-90s german cars in a wide variety of disrepair. Never been a huge merc fan, some models obviously being the exception. Picked this up from Birmingham, (The midlands, not Alabama...) and it seems to have had a few owners who aren't really clued up on these cars. It needs work, most critically under the front screen it needs some welding as well as the front inner wings and one of the jacking points and a few mechanical issues.
Disconnected the old full closure alarm system which was stopping the windows from working, PO attempted to remedy by splicing/ twist taping universal harnesses in....it was a mess. The engine bay harness also had caught fire and melted at some point, half of it was still working albeit dangerously. PO had it welded but they neglected to move the wiring for an aftermarket amp behind it. They were live and permanently shorting, explaining the battery drain. Ripped out any aftermarket wiring and made the rest of it safe. Got the clocks and interior lighting all working as well as the windowsReplaced the timing chain as it's a known weak point, new oil pressure sender,
On the trailer home
Back home and cleaned up
Note the low suspension, hydraulic lines had corroded, replaced them and didn't realise that the height adjuster was also seized. The jack under the car was down, and the resulting "ride height alternation" was amusing to say the least although I did get worried that I had blown the shocks past their limit
Once the adjuster was unseized things were a bit more...normal.
I'll be adding bits and bobs to this thread, most work has been menial (read boring). Most likely once the E9 is done and i've got some garage space spare!
On the trailer home
