Wanted automatic transmission shifter boot.(mysterious part number??)
bimoverde
california
Looking through the parts book i was not able to locate the rubber shifter boot used on the automatic transmission. Is the boot the same as on the stick shift cars ? Has anyone located a part number? Source for the boot? The transmission in may car is a borg warner, so it is possible that this rubber boot could have been used on other cars, but i have not found anything so far..
the attachment shows a picture of the shift linkage with the boot attached..
Hi,
Have you tried 25 16 1 200 013
It looks like part is NLA
E12
520 M10 Limousine, ECE525 Limousine, ECE528 Limousine, ECE530i Limousine, USA
E3
2500 Limousine, ECE2500 Limousine, USA2800 Limousine, ECE2800 Limousine, USA2800Bav Limousine, USA2.8L Limousine, ECE3.0L Limousine, ECE3.0S Limousine, ECE3.0S Limousine, USA3.0SBav Limousine, USA3.0Si Limousine, USA3.3L Limousine, ECE
E9
2.5CS Coupé, ECE2800CS Coupé, ECE2800CS Coupé, USA3.0CS Coupé, ECE3.0CS Coupé, USA
I checked for you- the ones I have are shot- sorry
Thanks for checking
This is an odd duck.. I can’t believe they were not used by other car company’s that used the 3 speed borg Warner trans
better picture of what i am looking for.. if i get a good one i could try having it reproduced..
I have one from my own car that i need myself, but if needed i could take measurements so you could produce a mould from it.
It isn't a complex shape i think, and tolerances are not tight at all. Basic shape is a cilinder with a bottom and a hole in it, and the cilinder is mated to a flat top surface.
can you send me some pictures of it and basic measurements..greatly appreciated..
my email : [email protected]
I love my automatic car and have no intentions to convert it to a stick shift...
Regards
Hervé
Some...
thanks Don..
what is the hight of the boot..
aim trying to see if this will work
..https://www.summitracing.com/parts/spe-6285?seid=srese1&gclid=Cj0KCQjwkZiFBhD9ARIsAGxFX8Bbh0EpWCyIlvTF6V1x3tRzTYMLVvH2y3dQTW9RfkyhX6FfYVHmvfoaAq_2EALw_wcB
My basic desciption as given in my previous post is not correct, It is a cilinder, but there is no flat shape merged to it.
Herewith some exact measurements + a drawing:
Height is 53 mm
Diameter is 76 mm (plus minus 2 mm, it's not easy to measure a floppy unround rubber part)
And it does have at the top a thickened ring, thickened to the inside. 7,5 mm thick and 5 mm high.
On the bottom it has folds and a hole. The folds are there to allow movement of the rod poking through it. Hole is 9,5 mm.
First fold is directed up into the cilinder. it is 20 mm deep.
second fold, also directed into the cilinder is about 7 mm deep.
The small cilinder sticks out by 2 mm at the bottom
hope this is helpfull.
