<50miles
Hello Everybody,
This weekend I finally saw the car after it came from the paint shop. Strangely, the painter decided to put multiple layers of clear coat on the exterior of the body, and the top areas of the engine bay, but not so many in the bottom areas of the engine bay where it would be partially covered by the engine. He also did not put that many layers of clear coat in the trunk area. Due to this, as you can imagine, the lower areas of the engine bay and trunk are not as shiny as the rest of the car. I asked about this and the reply I received was that those areas don't need as many layers of clearcoat because they would not either be readily seen (lower engine bay area) or not seen at all (trunk area). Does this answer make any sense?
Andrew
Andrew
