When I bought my E9, the trim panel under the steering column was only held in place by the wires plugged into the switches in it and the trip odometer reset cable. Needless to say this wasn't the most stable of mounting methods.
I've looked in the blue book and searched here, but haven't found exactly what I need. Usually it just says "remove trim panel." Since it was basically already removed when I got it I'm having a hard time reversing the process.
The foam was separating from the metal backing at the rear of the trim panel so I removed it and reglued with 3M Yellow Weather Strip Adhesive. (Worked like a charm - thanks forum tipsters!) Now I'm ready to reinstall it but I can't quite figure out the proper mounting points.
Could someone snap some pics of where its mounting points are (especially if you have relatively clean wiring under the dash)?
Also take a look at the posted pics and tell me if they look right. I believe the long piece at the rear should attach to the firewall somewhere. If this is the case should it be straight(er)?
Thanks,
Dan
Thanks,
Dan
