ECA90049
I have the panels off my 71 e9. I've WD-40 all the tracks for two days and still can't get the window to go up. But when I turn on the ignition and press the window switch up or down this toothed cap I'm pointing to moves one way or the other. So it would seem I'm getting power to the window and it's just stuck. I'm new to this but do you think mine is just stuck as well? If so could you give me a detailed guide to how to get it unstuck? I'm a rookie at this so any detailed help I can get is appreciated. Thanks, EOverthinking this guys, the window is probably just stuck. Pop the manual handle cover off the door card (assuming a '74 came with manual windows) and roll the gear drive away from you while pushing the window down switch. Careful you don't get your finger pinched. Or use the cool "window stuck" tool. This happens to my passenger window all the time.
