bicareful, zenith inat with air thermovalve: vibration caused banjo bolt lost
a friends car,
banjo bolt get loose due to vibrations in carb A...
but carb B: ...nada....gone
Has this happened to anyone else? I don't think we should jump to action and modify based on an N=1. We leave that to our politicians.
Here is a tech question, is a standard bolt, 8.8? so hard that it needs a special drill bit?
What about the wire, anything special? Stainless I assume, but needs to be malleable?
There is wire specifically made for this, as well as a pliers that make the process easier. I've been looking to pick up some in case I needed to secure some fasteners and have been lucky enough to come across wire and pliers at two estates sales for bargain prices.
Here's how to do it:
Here is an example of what you might find for supplies, though I'm not advocating making the richest man even richer.
I have lots of aviation grade safety wire and will send a few feet to whoever needs it. The wire and an example of the pliers are below.
You can by cheaper safety wire pliers online.
Even cheaper
