Sold: Turn Signal Wiper switch e3
JMinPDX
Portland OR
I’m pretty sure this is an E3 turn signal/wiper switch. Pre 74 cars with signal switch on the right side of the column.
$75 shipped in the US
I am looking for the right side wiper/wash switch for a '71 E9 Euro 3.0Csi. This looks like the one I need. Is there a part #anywhere on the item to compare?
Thanks,
Dennis
Thanks,
Dennis
this is the only number on it. Don’t know if they correspond to the actual part number. It came from a US spec 1973 e3. I will do some research this evening. But I recall that the PN’s are different between e3 and e9.
After some research I found the correct part number for this right side e3 signal switch I‘m selling:
61311355285​
looks like the e9 part number is
61311355322​
They look the same. But part numbers don’t appear to interchange with any other model.
Of course the e9 switch costs quite a bit more.
You are correct. The E9 controls turn signals, wash feature, and wipe. Apparently theE9 swith also changed after '74. Thanks for your response.
Yes they both changed for 74.
That’s right and I pretty sure the 74 and later switches interchange between e9 and e3
e3 switch I’m selling has the wipe/wash switch as well.
I’m looking for the dip switch that mounts on LH side of steering column of a ‘73 e9 CS (US) so let me know in case someone runs into one. Understand the one on e9’s is different than e3’s but not clear on differences. Maybe someone savvy can enlighten me!
Thanks, Denis
