- Messages
- 411
- Reaction score
- 254
Hi all:
I've got an excessive front passenger side negative camber wheel situation that I'm hoping someone can help me with. Basically, my alignment showed -1.6 on the passenger side and -.6 on the driver side. I was worried about excessive tire wear and steering impact on the pass side. My repair shop thought the strut housing was bent since no other apparent damage was visible -- suspension links, subframe.
They recommended that I order a used replacement strut. After the install, my passenger side camber reading is now -2.8!
So either the replacement strut is bent more or more stock strut was straightened at some point by a PO to remedy a bad camber situation.
Question is, what do I do now? Do I go back to my original strut and live with it, try to straighten the original or "new" strut at a qualified frame shop, modify the top of the strut tower to produce more positive camber with a bent strut or some other approach?
Has anyone dealt with this before? Thanks in advance for any advice.
