E9- 5 Speed Conversion mount kit
Candia4441
California
Hello all, 5 Speed Conversion mount kit from Coupe King check the picture I had this for a long time when I start my project but today was a day that I try it but didn't work My 5speed came from E36 M3 and didn't work I could use the transmission mount since it was right height but I put the other mount that didn't match on it and I use the bolt and nut if you check the pix you will know I paid $365.00 plus tax close to $400.00 if any one need this bracket just offer me and don't be shy I don't need this and I don't know what type of gear box is for I think he have to mention what type of gear box is for then sale the after market product but he didn't.
first pix is my bracket - 2nd and 3rd Coupe King
Isn't this mount strictly for the getrag 265?
What trans came with an e36 m3?
Hello, I do not have a clear picture but this is what I have check the pix. I will take a better picture tomorrow
yeah the coupe king is for a 5 speed from the 80 known as a 265 , the trans you have pictured is an e36 trans , you will need to make up a mount that fit that from scratch
Hello, Yes I did make a bracket from 3/8" metal plate and holds up very good but what Coup king have look nice and professional and I have been told that E36 gear box is much better gear box what do you think is that better choice?
you will want a 5 speed or 6 speed that fits the S54 , a 265 trans will not bolt up to an S54 , that coupe king mount does NOT fit a trans that will bolt up to an S54 you will have to make a custom mount like I did when I did an S54 conversion in a E12 and years later in a E9 , Personally I would source a 5 speed trans out of an e36 M3 and make your own mount
Hello, Thank you for your attention that's what I did I have a 5 speed from E36 M3 and I did make a custom mount for it but I tell you that's an easy part it is really a challenge to put that engine on E9 we fixing a problem after a problem specially you want everything to be nice and clean today our challenge was placing a battery on trunk and bunch of wires run from engine bay to under dash to install a new computer and we have to modify original M3 air filter to be able install a power booster and master cylinder I am using 2002 small power booster I had to cut the pedal pox short to get the booster close to fire wall and now I have a problem with the suspension sway bar that I couldn't fined any to fit since oil pan is not the original and is on the way and I can not install the sway bar if you did the same work please any hint what kind of sway bar can fit there thank you in advance
I'm confused.
Why did you order this then?
"This kit is meant to help facilitate the installation of a Getrag 265 5-speed into your vintage BMW..."
I'm confused.
yes you are right it's my bad I should of read it actually my helper finds it and send me the picture and I told him go ahead and buy, I should of go to site and check it, but again he didn't know what kind of box I am going to buy and now it is good for whoever need this part they don't have to spend 400 I maybe let it go for half price and spend that money for speed box since I have to install a speed box to be able have speedometer.
I'm ready to buy this set if you're ready to send it to EU(Spain). If yes PM please.
