Various E9 parts (located in Germany)
julianCS
Germany
I have various E9 parts for sale, located in Germany that I don‘t need. So preferably interesting for Europe members.
-CSi rear trailing arms (need to blasted and coated) without wheelhub, without driveshafts(!)
-rear subframe/carrier
-3.45 diff (no lsd)
-CSi rear sway bar
-CSi Front sway bar
-4 front struts complete with hubs etc
-1 front manual window mechanisms
-couple of electric window motor gearboxes most early style, one late style window motor gearbox(plastic case)
-CSi probshaft (for 4 speed Getrag)
-CSi ECU Engine Control Unit (maybe with engine loom have to search)
will update maybe some more parts and pictures
thanks!
For struts: 100€ per complete strut with hub.
The diff ratio should be 3.25. (edit: i looked up, actually it is a 3.45 -> 11:38) I will look if you are interested. I‘m located in east Germany, Leipzig.
-CSi diff (no lsd)
-CSi rear sway bar
-CSi Front sway bar
-2 front manual window mechanisms
thanks!
Hello, How much do you want for rear trailing arms I don't need a rear sub frame just a trailing arms I am asking since you put it together as a set But I only need a trailing arms thank you in advance let me know please
175€ per trailing arm, so both for 350€. But I don’t know if shipping is wroth to USA because it will be very expensive.
I agree with price since is heavy will you please fined out how much will be to shipping to US Los Angeles zip code is 91344
and question is trailing arms came from 3.0cs?
Depending if I can pack both together or need to pack individual. If i can get both together it will be 75€, if I need to pack individual it will be 110€ to USA.
They are for brake calipers and came with a CSi parts car, but there is physically no difference between 3.0 cs, 3.0 csi and 3.0csl.
Hello, lets be clear 350Euro + 75 Euro total 425 Euro for only trailing arms or trailing arms and brake caliper together am I right or you want to Itemize and explain please
350€+75€ OR 350€+110€ depending on how I can pack these. I can not say at the moment if I can fit these inside one box. Therefore two different shipping prices.
No brake calipers. No wheel hub (I still need them) For 350€ plus shipping you will only receive part numbers: 33321106869 and 33321106870 (look it up on Google please). These trailing arms are for fitting brake caliper, not for fitting drum brakes.
-3.45 diff (no lsd)
-CSi rear sway bar
-CSi Front sway bar
thanks!
-3.45 diff (no lsd)
-CSi rear sway bar
-CSi Front sway bar
thanks!
Hello,
Please check the attached picture where arrow is pointing that is the only thing I need how much will you asking for it.
please do not confuse me that is the only part I need the way it is in the picture and I can send you a $500 I dont know how much in euro will be
-3.45 diff (no lsd)
-CSi rear sway bar
-CSi Front sway bar
@Candia4441 ; its called a trailing arm, and generally Google will provide you with a nice answer if you want to convert 500 USD to euro's.
Remember; if you want something, and reach a high chance of succes, make it as easy for your counterpart as you can.
Hello, I haven't got my answer, do you sale the trailing arms left and right if it is for sale please price with shipping
Julian,
I may be interested in one early window motor gearbox. Please advise on price and condition.
Thanks!
Condition I would say is good for 40+ years, spins smooth but I have not looked inside. As for price, I would charge 40€ for it.
