What’s Wrong With This Picture ( Differential) ?
Patton
Atlanta GA
Represented as a “limited slip“ unit, the differential didn’t slip at all. Full lock , all the time.
We thought it might break loose. Finally, I removed it to discover it was welded-in-place.
3:64 internals. Does anyone have a limited slip gear set for sale?
Thanks in advance for your help.
Robert Patton 404-226-6678
Given how much power you will be putting into the axle, maybe call VSR1 about their LSD rebuilds?
Supposed to be able to handle more power than OE by using new stronger parts.
ugghhhh , Robert , I just sold the LSD diff out of the Bavaria to a fella out on the west coast . if you can't find one David Green can most likely build something for you
Brendan, David Green says that these are too old, no parts. Bobby said he would try to help, he had/sold me Tony's old inventory.. (Not expecting too much with Bobby.)
RP
Back in the day, did you weld it?
I talked with Korman a couple months back about rebuilding a 3.45 LSD I have for my car, they said they can still do it.
RP
Are you talking about Bobby Thrash in Braselton? He may have some special used parts in the back with his Inka CSL and Technoviolet E36 M3.
I also called Jim Blanton, he didn't have the parts either.
Not sure if this is helpful but I have had several cars over the years have their rear diffs rebuilt by Jim Rowe at Metric Mechanic in Rich, MO. For me, always quality work and no complaints. Reasonable turn around time. He is currently building a 3:45 60% LSD for my 1973 e9 CS.
One of previous owners had a repaint in 2003 and painted Anthracite Grau with tan interior. I am taking back to original color and trim : Ceylon Gold with Black interior. Building a M30B34 bored to 3.7L with 50mm ITBs and fuel injection, headers, 5 speed conversion , etc. Should produce somewhere close to 300hp. I plan to post lots of pics when I am finished. CAN"T WAIT !!
