any one can help me with the right tire size, I have a 16 X 9 inch wide wheels for back and 16 X 7.5 inch wide for front what size a tire I should use to be a same height back and front.
					e9coupe.com
				Hello,@Candia4441 the more important question is what the offset of the wheels are. this discussion has been pounded thru numerous times on the forum and with you ... we have provided you with further insight in understanding offset in relation to wheel width. thanks @eriknetherlands for posting a link to my FAQ on wheel + tire sizes / options. the fight on the coupe is to keep from hitting the fender lips with the tires as well as hitting the springs / struts. a 7.5" wheel on the front may fit but is more likely to hit the strut with a 16" wheel ... depending on the offset, the tire might hit the fender lip - you will need a different offset that et 11 (which is the offset for a 7" wheel). you will probably need about et17?
the standard size wheels for 16" tires is 205/55-16 front and 225/50-16 rears. look up tire specs on tirerack.com and check out the wheel width variables for the given tire size.
thank you again, I choose a 245/45/16 for rear and 225/50/16 for front I have a E46 engine and Wilwood big brake system I hope all this modification will work right the reason back rim is to wide thats how it came it is epsilon wheel that I restore it it is very nice wheel I look all around to fine a drum 9.5 is to wide but I couldnt fined any I hope that will not give me a problem if it dos I have no choice to spend another 3K for BBS225/50-16 is the same diameter as the 205/55-16. this is listed in the referenced FAQ.
see below for a screenshot from tirerack.com. the 9.5" rear is going to give you trouble with the 225/50-16. there aren't a lot of wide 16" tires - i have included a pirelli p zero rosso in 245/45-16. the tire section width is 9.5" and the rim width range is 7.5" to 9". i think you are going to have all kinds of problems with a 9.5" rim on a coupe.
Hello I couldn't fined a barrel If I could fine 1 inch shorter barrel would be the best front is 7.5 inch and it is ok back is the problem that is 9.5 inch widegood luck, don't think the 225/50 is going to fit in the front. you better tightly roll the fender lips and have camber plates. i caught both fender lips with 205/55-16's. no idea about the rears. i have heard that 245's fit on 17" x 9" wheels - with a few mm to spare. that's not much room. you have to remember that when shocks / spring compress, the clearances get tighter
iMHO, you should have changed the lip / barrel on the wheels to make it a proper size for the e9. i could be wrong, but i don't think i am. i just hope you don't learn a very expensive lesson.
Hello, and thank you all, the tires that I order I got them yesterday I install it and works just fine I had to roll the fender to make it work rear is 245/50/16 and front is 225/55/16 but I have a coilovers from Coilover Depot front and back looks very nice with fat tires thank you all.Albert,
PM sent
