Parts clear out, mostly e9.
eriknetherlands
Netherlands, Eindhoven area
For sale:
(Edit : for sale/sold status updated 1 Sept 2023 )
-Half shafts, 100 euro's for the set.
- E3 fuse box lid, 15 euro's
- Wood gauge cluster with chip at the bottom-middle, has the 8 ribbed nuts at the back. 80 euro's
- Wood gauge cluster with loose rings, and loose bolts. Missing the 8 ribbed nuts at the back, but any m5 nut will do, I can supply them if wanted. (I've cut and included 2 new tube sections as they were missing + I could now easily copy from the other cluster). Wood also has chip on the side. 70 euro.
- repro orange diagnostic connector cover, 10 euro
- Window cranks, 20 euro /set. chrome is rough with a few scratched and small chips. plastic parts have marks from incorrect removal attempts (screwdriver pinch marks)
- repro Walloth spare wheel tire pin. 10 euro
- brown ashtray set. 40 euro. Chrome has some scratches/pits.
- jack, confirmed for e3 by HBChris. 20 euro.
And now some rough parts:
- viscous coupling. No knowledge on function or if they fit e3/9. Willing to test them for you, but you have to teach me how. Free, 0 euro.
sold items:
- fuel door, needs a sandblast, and repaint, 35 euro-sold
- (all sold): 3 fresh sandblasted and zinced head light buckets, I think euro style. 2 of them have 2 fresh zinced and re-installed adjustment pins; 7 euro's each. 1 bucket is missing the 2 adjustment pins (they snapped while removing), 4 euro's -Sold.
- Fuel door rubber, 40 euro Sold. Has a tear between the 2 openings at the back, not visible when installed & it actually makes it easier to install.
- wiper mechanism parts from an e3, threaded sleeves cross match to e9. Not sure if the parts with the pin+ ball joints fit e9 also, corroded pins anyway. Sold.
- Red coil. Not sure if it works. Sold
.- 2 Rubber 'ears', for between the armrest and front door panel. SOLD
Also e3 trunk bin (needs cleaning) and e3 wiper mechanism parts: the fixed section and the long push rod
Edit: parts are gone.
Edited & updated 16 june:
Sold sofar :
- Wiper mechanism part to Halboyles
- Coil & headlight buckets to Autokunst.
- fuel door to Jefflit
Sorry @paul cain , no headlight buckets left. Autokunst beat you to it.
updated the list of parts in post #1 to identify which are still available.
DeQ passed on the window crancks, so still available. (they have some chrome corrosion, and need rechrome to get up to that amazing DeQ standard.
Thread updated; fuel door has been sold and is en route to Alprada.
still available:
- 2 wood cluster panels
- 2 half shafts
- E3 fuse box door
- ashtrays
- 'ears' for the upper mount of the armrest (E9)
- Spare tire threaded pn from Walloth&Neesch
- side console panels (5/10 condition, need to be recovered in new vinyl to look great)
