Mystery Connector
TG-2002-320i-328ci
Tucson, AZ
Here's an slightly embarrassing issue: whilst re-assembling my intake manifold/C-pipes etc I have found a connector that I cannot seem to find a home for.
It's from the same wire loom as the Air Slide Valve connector, and the same type - and the pretty much the same length of cabling. It's not the connector for the Start Valve, as that comes over the top of the engine from the passenger side. I have no recollection of removing any electrical connectors other than the two mentioned above...
I'm perplexed, hence the reaching out to this board of experts.
There are 2 sensors at the AAV area.
Water temperature and Cold start temperature time switch
